pony loader
amertrac
01-04-2006 14:05:29
i have a small manure bucket loader on my mh pony.it has a trip bucket. i was using it today when all of a sudden the bucket would not lock.i checked for something broken nothing the pin that locks will not retract enough to let the little bar go past the pin the bolts are all in and tight .the release rod goes all the way back.it can not go back any more it seems the bucket may have moved back but i checked the pivot bolts they seem ok . maybe cutting the rod and putting some kind of turn buckle type adjustment in ? any ideas
51Pony
01-06-2006 15:30:12
 Re: pony loader in reply to amertrac, 01-04-2006 14:05:29
I've heard that the Pony frame wasn't really of sufficient strength to use that loader very hard. The frame members would tend to crack. Be careful!
51Pony
01-04-2006 14:18:07
amertrac,
I think that loader is just broken beyond repair and that you should consider selling it to me! Just fooling ya. A picture sure would help. Not many of us out here have the loader to be able to help you with this question. Could there be something behind that's blocking it?
amertrac
01-04-2006 15:03:30
 Re: pony loader in reply to 51Pony, 01-04-2006 14:18:07
i think tomorrow when i thaw out i will use a bar to force the bucket forward and check to see if something is loose.and you are right this is the only pony i ever saw with a bucket , it also has a cicle bar mower . i was lucky to pick it up for 1500.00 bucks in september
