65 massey three point problem
Brian in ks
01-08-2006 15:51:46
Never posted a question on this site. But have learned a lot reading the others. My problem is after using my massey with a 3pt. blade on back for 45 min or so it don't want to lift the blade. I can lift it by hand but it will settle down to the ground. I changed the fluid in transmission although not sure 3 pt. uses same oil and it didnt help. Thanks in advance for any ideas.
Aaron Ford
01-12-2006 16:35:22
 Re: 65 massey three point problem in reply to Brian in ks, 01-08-2006 15:51:46
It sounds like a crack somewhere or maybe a failed o-ring. Try this. Remove cover from right side (dipstick), and move hydraulics and look for leak. Swirling fluid would indicate a relief valve lifting. Write back if more info is needed.
Aaron Ford
01-12-2006 16:34:59
