Getting the injector pump off a MF 30 backhoe (same as tractor)
charels
06-06-2000 19:54:47
My injector pump has gone bad. Its a "CAV" and has three nuts that hold the front of it onto 3 bolts. Two are easily accesible. The third is up against the block on the backside of the pump body. I can see it but cant get a wrench on it Its positioned below the top of the pump and can be accesed only (apparenly)through as space about 1" high by 2" long. Ratched head would never fit in. How do I get this out! Please!
E.Beukeveld
06-07-2000 07:10:59
 Re: Getting the injector pump off a MF 30 backhoe (same as tractor) in reply to charels, 06-06-2000 19:54:47
Buy a 1/2" starterwrench it is bend and will
loosen your nut of the pump.
Pump is the same as MF165 with Perkins A4/212 engine
