Voltage regulator on a generator
B. Jones
01-22-2006 14:31:10
Our 180 MF has a generator which runs the tach. I wanted to keep the tach, so I put a 1974 chrysler voltage regulator hooked to the field terminal and left the cutout to unhook the generator when you shut it off. My long post is over on the Tractor board if anyone is interested. I actually hooked the hot wire from the electronic voltage regulator to the arm. terminal on the generator so it is only hot when the tractor is running. It seems to be working good at about 14.3 volts. B. Jones
