Need a good machine shop
Ben Massey
02-02-2006 13:56:02
Can anyone recommend a good machine shop that has experience working with cast iron and can weld my MH 55 manifold. There are several cracks that need to be gouged and welded. I live in northern Wisconsin and I don't know anyone who can do it.
Thanks,
Ben
Dave Sherburne NY
02-04-2006 19:45:41
 Re: Need a good machine shop in reply to Ben Massey, 02-02-2006 13:56:02
Just remembered I still have the phone book. It's
Voelker Machine Shop 417 N 1st street, Abbotsford 715 223-3383. You start out by saying,"You
probrobly can't fix this, but would you take a look
at it."
Dave Sherburne NY
02-04-2006 19:38:50
You might try velker, maybe voelker in Abbotsford Wi . I used to live there, never found
anything he couldn"t fix.
garvas
02-03-2006 04:40:31
There was a guy here in Texas that was good. Got the chance to watch him. He always reversed the leads on the welder when welding cast. He would then place a hand (no glove) about a foot from where he was welding. When his hand got hot he stopped and let everything cool down. Never saw any of his cast welding crack. This was on printing presses but the principal should work on any cast. You might let a local welder try this.... Lots luck
msb
02-02-2006 21:10:17
You are looking for a real craftsman.There was a guy who used to post here at YT by the name of George from Maryland.Sorry ,I no longer find his e mail address,but maybe if you ask for him at tractor talk,maybe he is still around.He does some fantastic work.Reasonable too.
Don-Wi
02-02-2006 20:28:34
I've done limited weldiong on cast, one was the manifold on our 1855 Oliver. Whe it was in the shop the manifold was rusted in the muffler and broke off inside the manifold. I made up a sleeve out of scrap at work and welded it on. SO far so good, but it's only been a few months. I also welded a cast hitch on our JD disk back in high school. I grooved it way out and filled it in 1 layer at a time and chipped off the slag in between. It's been holding for about 5 -6 years now no problems. Got any pictures of where it's broke/cracked? I work in a machine shop, and while I'm no cast expert I have some experience. I am located in Kaukauna. There is some other guy somewhere on this website who is a real guru at cast, just don't know his handle or what board to find him on. Maybe tool talk.
Donovan from Wisconsin
marlowe
02-02-2006 16:40:57
that is a lost art was a guy in waupaca wi. but he's dead but you might call STUMPNER WELDING in BERLIN WI 1-929-361-2287 or SHANAK FOUNDRY&MACHINE CO. in waupaca wi. 1-715-258-7421 try them first SLOOOOO OOW but very good
Alberta Mike
02-02-2006 17:47:18
 Re: Need a good machine shop in reply to marlowe , 02-02-2006 16:40:57
Well, at least you didn't leave the phone number of the deceased.
marlowe
02-02-2006 17:59:42
 Re: Need a good machine shop in reply to Alberta Mike, 02-02-2006 17:47:18
i do it's in my little black book but he must be out got the answering machine . just kidding . i always think of old JOE he had one arm and was blind in one eye and was deaf from a exploison from a blasting wedge in the black smith shop that killed my grandfather an two others back in 1952. he was one of the best people in the world
Alberta Mike
02-03-2006 06:28:18
 Re: Need a good machine shop in reply to marlowe, 02-02-2006 17:59:42
Is it my imagination or does there seem to be less and less of those kinds of guys around these days? When I was a kid in the 50's, there seemed to be lots of those guys around, now I am hard pressed to think of one. Maybe I'm not looking very hard or maybe I'm not looking at all.
Harris Guy
02-02-2006 14:14:47
You are looking for a Blacksmith/welder's son, he
will heat the damaged manifold , repair, cool for
a slow 24 hours, or more. Until you find the guy,
you are wasting words on rod-hot welders. Most
manifolds can be repaired, if cracked, rotted is the need for replacement. Good luck.
Ben Massey
02-02-2006 14:46:20
 Re: Need a good machine shop in reply to Harris Guy, 02-02-2006 14:14:47
Harris Guy,
Agreed. I know that welding cast is an art and that there is pre and post heating involved depending upon the thickness. Thats why I hope someone here has had one done and can recommend someone good. After welding the ears the flanges will have to be milled.
Thanks,
Ben
