Blowing oil
Charles Wilson
02-06-2006 10:15:35
I purchased a 135 a few years back,at the time of purchase the tractor had been rebuilt 8 months, it sat with no use for 6 months before I purchased it. I pull the oil stick when running and drops of oil are being spit out, but tractor never uses any oil. This has been happening when I first got the tractor. I know tractor was used very little after rebuild, and was rebuilt by a reputable shop. I have worked the tractor hard, ran marvel mystery oil, sea foam but still spits oil out dip stick hole.
Leland
02-07-2006 08:34:04
 Re: Blowing oil in reply to Charles Wilson, 02-06-2006 10:15:35
If it's not using oil don't worry my atv and my mazda pickup do this also it is the way they are built
Lou
02-07-2006 08:08:06
Ive always been under the impression you should not pull the dip stick or open the fill tube when a motor is running. But if you think you have a serious problem and want to sell the 135 at a deep discount, Let me know. Grins, Lou
Appreciate the Help
02-07-2006 05:07:52
Tractor operates like a champ no complaining here, best tractor I own as far as performing just need a front end loader for it.
Texas Red Neck
02-06-2006 13:01:07
Might check your crankcase vent and be sure it isn't stopped up.
Rod in Smiths Falls, ON,
02-06-2006 10:27:02
Have you tried the same thing on another tractor with a similar engine? You might find that they all spit oil in that situation.
