MF-85 Hyd.
Bob in Mi.
02-07-2006 16:13:59
Does a MF-85 have an internal hyd. pump or external? How expensive to repair. 3 point does not work. Thanks, Bob.
Fred Wolfe
02-07-2006 20:21:46
 Re: MF-85 Hyd. in reply to Bob in Mi., 02-07-2006 16:13:59
I still have the MF 85 my dad bought new and still does a days work. I have a 3 Super 90 diesels, 2 MF 85 gas tractors, one MF 97 diesel.My brother has 2 MF 85 gas, 65 diesel, MF 50 gas, Super 90 LP, Super 90 gas and MF 95. Only replaced 1 hyd pump. The 3 point may work, you need to turn the valve under the seat in or out and lock one hyd lever back.
marlowe
02-07-2006 16:34:35
it's inside the the center section of the trans. dose your pto work?
Bob in Mi.
02-07-2006 16:46:25
 Re: MF-85 Hyd. in reply to marlowe, 02-07-2006 16:34:35
Not sure. Tractor is at auction. I had a to-20 that had a bad pump, water got into the oil and froze. It was located in bottom of trans. My question is: does the pump come out the bottom or does the tractor need to be broken in half. Does pump run off pto shaft?
marlowe
02-07-2006 17:21:08
 Re: MF-85 Hyd. in reply to Bob in Mi., 02-07-2006 16:46:25
i'll tell you what im a massey die hard but i'd pass on that 85 seeing that it's not yours first pump parts are to find and if you find them they might be more then you pay for the tractor also engine parts are few but pricey and the 85 was not all that good of tractor in the first place they had PTO and HYD. trouble from new on
Bob in Mi.
02-07-2006 18:37:17
 Re: MF-85 Hyd. in reply to marlowe, 02-07-2006 17:21:08
Thank you for your honesty. I have had a To-20 and loved it, just was not big enough. Looking for something bigger, and would like to find a hundred series ford. Those I have worked on. Thank you for your help. Bob.
marlowe
02-07-2006 18:42:40
 Re: MF-85 Hyd. in reply to Bob in Mi., 02-07-2006 18:37:17
you want a good all around tractor find your self a MF-65 thats just about the best all around tractor out. easy to work on and all kind of parts av.
