mf135 hydraulic
Bruce boily
02-08-2006 02:17:02
Help
I have no hydraulics. I have been using the draft right up with constant pumping. What damage have i done.
DavidP, South Wales
02-08-2006 10:30:30
 Re: mf135 hydraulic in reply to Bruce boily, 02-08-2006 02:17:02
Hi,
Unlikely that you have done any damage unless you have 'cooked' the oil. You may have then damaged the control valve. Your problem might be as simple as a broken spring in the hydraulic linkage..... .only problem is you will have to remove the lift cover to find out.
Please come back with more details.
DavidP
