Crankshaft Nut Torque
CONTRADICTIONS
Alberta Mike
06-14-2000 14:19:16
Through the forums last winter, I asked how many pounds of torque to use when putting on a 7/8" fine thread crankshaft nut on a Continental 4-cylinder flathead engine. It only holds on the pulley (keyed) which drives the water pump and the generator. I received answers ranging from 100 foot pounds to 200 foot pounds (including locktite sometimes). The guys locally at the Continental Engine shop could never give me a value until today when the fellow on the front desk told me their manual said from 100-120, but then said he wouldn't go over 80 if it's an old engine and the nut has been on and off over 50 years or so (I don't think it's been off very often, maybe even only the one time). So my question is obvious, what do I torque the nut to? I'll go with whoever sounds like they know best.
haci yilmaz
02-04-2002 03:50:35
 Re: Crankshaft Nut Torque - CONTRADICTIONS in reply to Alberta Mike, 06-14-2000 14:19:16
Dear Sir,
We introduce ourselves as GENMOT CRANKSHAFT MANUFACTURING CO. which is
manufacturing crankshaft since 1987.We are the new export department in
GENMOT LTD.We evoluated the old faxes which we send each other.And we
think that it can be good to send you our new informations.If you interested in
we hope we will make good works with you in future.Now we enlarged our
manufacturing crankshaft since 1987.Now we enlarged our manufacturing
field and established genmot group ltd. Genmot casting factory, Genmot
machining factory and genmot automotive marketing-trading co. ltd.we have
approximately 162 kinds crankshaft in our production line from 1 cyl. to 8 cyl. we sell our products 55% to domain market and export 45% to foreign market
such as Italy, Belgium, South Africa, Mexico, Sudan, Greece, Spain, USA,
Germany, England, Danmark, Algeria, Maroc, Irak, France, Iran, China, Hungary,
Argentina, Chile....
BEST REGARDS
Mr. HACI YILMAZ Fax: +90-332-238 57 76 NOTE :AS WE ARE GENMOT BOUGHT THE CRANKSHAFT LINE OF MERCEDES BENZ IN 2001.
WE CONTINUE TO PRODUCE VARIOS CRANKSHAFT WITH HIGH QUALITY AND ECONOMICAL PRICES
bob
12-11-2000 12:17:24
the 120# sounds aboiut right for a7/8th bolt I wouldn,t go less because of old bolt .Torque values are sety up on cleaned bolts also values ghange wheather you use lubricant Values are usually dry condition
Chip
06-15-2000 09:36:12
What does your manual say? I would follow that.
