MH30 3 point hitch
Bill Marko
02-17-2006 03:57:23
Will a MH30 3 point hitch work on a MH44?
redbastrd
02-17-2006 12:28:20
 Re: MH30 3 point hitch in reply to Bill Marko, 02-17-2006 03:57:23
I have 2 Massey 3 point plow hitches, I agree , the Hitch -All is stronger, I run a 5 foot brush hog , and a 7 foot back blade, and a 7 foot chisel plow off of them, and I havent broke anything yet, never hit a rock though either! I did see a complete Hitch - All sell on ebay a few weeks back, I thin it went for around $800, very hard to find someone who wants to part with either style hitch. Bob Doucet, from Holmen,WI. , makes and sells reproduction parts for both style hitches, he does not make the castings that fit on the lift shaft, they are the hardest part to find. His number is, 608-857-3153
Rod in Smiths Falls, ON,
02-17-2006 15:28:01
 Re: MH30 3 point hitch in reply to redbastrd, 02-17-2006 12:28:20
Uh, how do you get on and off a MH30 with an implement mounted on the 3pt hitch? Climb over the plow?
Bill Marko
02-19-2006 12:07:49
 Re: MH30 3 point hitch in reply to Rod in Smiths Falls, ON, , 02-17-2006 15:28:01
I use to have a MH22 that I pulled a 2 bottom 16" plow with and I had to climb on top of the implement to get unto the tractor.
Harris Guy
02-17-2006 11:23:11
The bolts would fit, however a 44 is reknown to break apart these modified cultivator hitches. If
the lift shaft is below the PTO housing, you need
to be careful all the time. Hitting a stone with a
back blade can snap a lift arm anchor. If you plan
to work, better to find "Hitch-All", the durable
MH 3 point, found on '54-'55 44 Specials, some 33's. The lift shaft is above the PTO, braced well
for active use. Good luck.
Bill Marko
02-17-2006 12:10:46
 Re: MH30 3 point hitch in reply to Harris Guy, 02-17-2006 11:23:11
Mr. Guy, Thanks for the information and advice. Do you have any idea where to look for a "Hitch-All?
Harris Guy
02-17-2006 17:01:14
 Re: MH30 3 point hitch in reply to Bill Marko, 02-17-2006 12:10:46
Bill,
You have to keep checking ads on the MH sites. I
believe there was a 'Hitch-All' on this site, if your notice the classifieds column, to the left. You click on, type in 'massey', scroll down the ads. That ad was probably one month ago, no doubt
gone-fast. Prices can run from 3 to 8 hundred,
since it is the preferred, real thing. People
list 'down tractors' to part out, you just make a
habit of viewing the MH ads. Good luck.
