Stuck clutch on massy combine
carl in nc
06-15-2000 19:23:04
what's the best way to unstick a clutch on a 410 massey combine. i should have left the clutch pedal pushed in but i didn't.
Danny
06-19-2000 13:02:58
 Re: stuck clutch on massy combine in reply to carl in nc, 06-15-2000 19:23:04
The BEST way is to remove the clutch and disasemble it and clean up the plates and splines. Another way is to get it going in high gear and jump on the brakes with the clutch blocked down. One way is a lot safer than the other. I vote you remove the clutch !!!
carl in nc
06-19-2000 18:24:51
 Re: Re: stuck clutch on massy combine in reply to Danny, 06-19-2000 13:02:58
i tried the jumping on the brakes in high gear but so far it hasn't worked. it has always come unstuck before in reverse or low gear with very little effort.
