1953 3 cylinder diesel tractor hydraulic system
Buck Orser
03-05-2006 08:16:59
I am thinking about hooking up a back hoe to this tractor but I need to find out what the pressure and volume in gallons per minute or equivalent is of this machine's hydraulic pump. Can anyone help out with this info or a source where I can find it? Thanks.
Ed Lotterman
03-05-2006 23:01:11
 Re: 1953 3 cylinder diesel tractor hydraulic syste in reply to Buck Orser, 03-05-2006 08:16:59
Buck: It depends oh how heavy a backhoe. This is not a very heavy tractor and the hydraulic pump is limited. I understand that you can mount any hydraulic pounp with an SAE B -2-hole mounting on the nose of this tractor and drive off the front of the crankshaft. That might give you the hydraulic capacity you will need for most backhoe attachments
Big Dean
03-05-2006 13:31:48
The three point pump for those tractors is 4.5 GPM at 2000 RPMs. The pressure according to what relief valve it has it could be anywhere from 1750 to 2800 psi
