MF3165 STEERING
CHRISGA.
03-11-2006 09:25:26
Well I've done it this time. took the steering cylinder off and resealed it reinstalled and when i run the engine and try to go left it spins the steering right. BIG DEAN NEED YOUR HELP AGAIN. WHAT IN THE DEVIL HAVE I DONE THIS DIDN'T LOOK TO BE THAT DIFFICULT. THANKS CHRIS
Big Dean
03-11-2006 09:57:10
 Re: MF3165 STEERING in reply to CHRISGA., 03-11-2006 09:25:26
Hi Chris I suspect you have the lines crossed that will cause that. Change the lines if that does not fix it get back to me Big Dean
CHRISGA.
03-11-2006 10:14:51
 Re: MF3165 STEERING in reply to Big Dean, 03-11-2006 09:57:10
HI, BIG DEAN. HAD THE LINES THE OTHER WAY AND POWER WOULD NOT WORK. CONSULTED THE BOOK AND IT SHOWS PRESSURE LINE FROM TOP OF PUMP TO THE PORT CLOSEST TO THE MIDDLE OF CYLINDER AND THE RETURN LINE TO BE FROM PORT CLOSEST TO SHAFT END TO THE SIDE OF THE PUMP. IS THIS CORRECT?
Big Dean
03-11-2006 12:38:28
 Re: MF3165 STEERING in reply to CHRISGA., 03-11-2006 10:14:51
Chris here is a picture that show the line location for the MF3165 if it works
CHRISGA.
03-11-2006 13:32:22
 Re: MF3165 STEERING in reply to Big Dean, 03-11-2006 12:38:28
THANKS FOR THE PICS I HAD THEM BACKWARDS TURNED THEM AROUND AND READJUSTED LINK IT WORKS GOOD IN ONE DIRECTION (TO RIGHT) BUT IS POOR AT BEST TO LEFT. I WILL KEEP PLAYING WITH IT. THANKS BIG DEAN. CHRIS
Big Dean
03-11-2006 14:52:16
 Re: MF3165 STEERING in reply to CHRISGA., 03-11-2006 13:32:22
Chris That steering has to have enough slack in it to to open the seletor valve wide open in both directions before the wheels start to move with the engine shut off. The pins in the ending of the centering turnbuckle will cause that problem it takes very little wear on those pins to cause that problem. here is anothere pictur for you on that. There is another set up that is a little different from this that yours may have Big Dean
