mh-50
booh
03-12-2006 14:36:17
I have a mh-50 engine gas z134 with less than 100 hours on a new motor. It has a new carburator also. The motor seems to be very strong but it will only run if i keep the choke about 3/4 closed. When i pull the choke out "open" the engine will backfire and die. I checked the valve lash and they are fine. When the govenor kicks in i watch it move but it doesnt make the motor rev up. The carburetor is new and came from this site so i know that it isnt that. Does it sound like a manifold leak.
Dale Garver
03-12-2006 17:43:49
 Re: mh-50 in reply to booh, 03-12-2006 14:36:17
Sorry for repeats
booh
03-12-2006 21:52:50
 Re: mh-50 in reply to Dale Garver, 03-12-2006 17:43:49
I have good gas flow. I pulled te plug out on the bottom of the carb and gas runs out real fast
Dale Garver
03-12-2006 17:42:12
Check the fuel flow from the tank,The fuel shut off valve may be clogged.
Dale Garver
03-12-2006 17:39:48
Check the fuel flow from gastank to carb.The fuel shut off may be clogged.
Dale Garver
03-12-2006 17:39:27
