Won't start
'61MF35
03-13-2006 03:00:33
I'm a fairly new owner of a '61 MF35 and I just replaced the head gasket, installed new fuel injector, and reassembled it. It rolls over, but it won't start. Any suggestion on troubleshooting?
Also, it has an electrical plug to warm the glow plug. Typically, how long should it be plugged in before trying to start it?
Thanks
Dan
ben27
03-13-2006 10:48:41
 Re: Won't start in reply to '61MF35, 03-13-2006 03:00:33
is The Diesel pump is still timed right?
old
03-13-2006 08:23:12
Sounds like you have air in the fuel system. I don't know much about that tractor but if you can crack open the lines at the injectors and turn the engine over till you have fuel leaking out of all the injector line. Keep turning it over as you tighten up the lines again or you will get air back in to them. Another way to some times get it started again is to pull it till it starts but that can take a long time
marlowe
03-13-2006 08:05:56
did you bleed the air from the fuel system ?
