Hydraulic pump ?s for mounting a Massey Ferg 220 Backhoe on my TD-6
Anton
06-22-2000 09:46:08
I just acquired a MF220 backhoe, 14' reach w/ vertical outriggers, and am installing it on my TD-6. I recently made a very stout 4-link ripper for the TD-6 and am making a custom quick hitch between it and the backhoe.
My ? is this: I need a hydraulic pump with more power than the TD-6's engine mounted unit, and I don't know which would be best. I would like to use as much of the 34 hp that the TD-6 develops, if new, to run the backhoe pump. This means I need to optimise for the flow vs. pressure that the MF 220 Backhoe was designed for. I've come to understand that pressures where limited to 1500 psi or less on older hydraulic equipment, to which this certainly applies. However, all of its plumbing, o-ring connections, etc. and cylinders, look like stuff that would be rated for higher pressures. I'd love to know what psi and flow I should target the MF 220 for. I believe this backhoe was made primarily for the MF 200 crawler, does anyone know what its hydraulic pump specs were?
A this point, with what I know my solution is this: Given about one horse power required per 1 GPM flow at 1500 psi I think a Prince 21-spline 40 GPM 1000 RPM PTO pump would work perfectly but I am not sure. If I connect this pump through a PTO extension shaft (6-spline 1 3/8" female to 21-spline 1 3/8" male)connected to the TD-6 tranny's PTO output shaft which turns at about 850 RPM, the output of the 1000 RPM rated pump will decrease 15% to 34 GPM. At this flow I might be able to get 1500 psi. If I set the reliefs to 2000 psi or so, I am thinking that when I bog the hoe down, my engine will likewise bog, which will increase my torque, and therefore my psi will go up as my RPM and flow drops off. This will achieve good breakout force while having fast cycle times.
Does anyone know if I am thinking straight? Please inform.
And thank you very much, in advance.
