Power Steering
Charles wilson
03-27-2006 09:34:17
I would like to add power steering to my 135 MF, I am looking into after market units, all help appreciated>>
cdmn
03-27-2006 18:28:18
 Re: Power Steering in reply to Charles wilson, 03-27-2006 09:34:17
Don't overlook an MF20. (It's a 135 industrial) Might find one that's being parted out. My nephew likes his.
DavidP, South Wales
03-27-2006 10:08:50
Hi,
First of all you would have to get the correct unit for your tractor depending whether it is a straight or swept axle. PAS units do tend to loose a lot of efficiency if you have wear present. This can be in the ball joints but is normally in the drop arms on the steering box. You may not have that type fitted. (MF UK) used to provide a new steering box to alleviate this problem. Maybe before spending a lot of money check the condition and lubrication of your ,axle pivot pin and bush/es, king pins and king pin thrust bearings. Also any excess play in the steering column. Any one of these could be making you work harder than you need to.
DavidP
Charles wilson
03-27-2006 10:35:42
 Re: Power Steering in reply to DavidP, South Wales, 03-27-2006 10:08:50
All is well with steering I have just gotten lazy, and thought how nice power steering would be.
