mf1155 hydraulic pto
arrock
03-31-2006 09:59:13
has anyone come across this?
the pto will engage on its own after tractor has run awhile. i have rebuilt the hydraulic control to no avail. dont understand how pto can engage, on its own with control if off position. i can shut off mechanically from the rear,
whats wrong?
caston
05-09-2007 23:54:13
 Re: mf1155 hydraulic pto in reply to arrock, 03-31-2006 09:59:13
Hi
We had this issue with our 1155 an what happend was that the pto would keep running (with load) even if it was switched off. we extracted the pto ftom the tractor and examined the pto discs. a few discs where in several pieces, some or many koggs was damaged or lost or schredded into fragments.
We replaced the discs an put it togher again. But be careful, 155 hp is too much power for it's pto.
/mats
MF rules
04-02-2006 18:49:50
My Massey 1135 and 1155 PTO's coast or free spin whenever the engine is running..... when you hook a PTO shaft to then they stop spinning. They have always been like that since they were brought home new from the dealer....nature of the beasts!!!
barnrat
04-01-2006 04:51:21
On most of the 1000 series Masseys that I have come across the PTO spins when the lever is off, especially when the oil is cold. It will usually stop when you have a PTO attachment hooked to it. Even then I've seen them spin over light pto loads like a hay tedder with the PTO lever off.
marlowe
03-31-2006 17:14:56
dose it do it with a load on ? or dose just the shaft turn with no load on it the latter is common. just asken
arrock
04-03-2006 09:58:55
 Re: mf1155 hydraulic pto in reply to marlowe, 03-31-2006 17:14:56
the pto runs under a load. have a tandem manure spreader, really fill it with manure, and will run on its own.. have heard of this in other 1155's no one knows problem.
