Ignition Coil
Adam Doman
04-03-2006 08:21:39
Just bough an old mf 135 and working on getting it up and running. I for some reason don't have any fire and I'm thinking maybe I don't have the ignition coil hooked up right. My question is I know you've have the ground wire going back to the distributor cap but what are you running the other wire to? I have an IT shop manual but it really doesn't show where you tie the other wire from the ignition coil to. Any help is appreciated.
old
04-03-2006 09:16:56
 Re: Ignition Coil in reply to Adam Doman, 04-03-2006 08:21:39
Well the + side of the coil goes to the ignition switch. The side of the switch that is hot when the key is turned on.
