Firing Order on MF 135 Perkins 3 Cyl
Adam Doman
04-06-2006 07:00:53
My question is I know the firing order is 123 but on the distributor cap is where I'm curious if I got it right. I currently have the plug wire running to the distributor cap starting from the bottom right as 1-2-3. Is this right on the distributor cap or is it wrong. I notice it back fires one time about every 20 seconds. Could just be my plugs or wires...don't know. I am just wondering if I have the plug wires going into the distributor right. Any help is appreciated.
Bill in TN
04-06-2006 07:31:06
 Re: Firing Order on MF 135 Perkins 3 Cyl in reply to Adam Doman, 04-06-2006 07:00:53
Set the number one piston to top dead center then remove the cap and see where the rotor is pointing as the #1 plug needs to fire on the compression stoke near TDC. Hope this helps....
