444RC Wheel wobble
Ben Massey
04-12-2006 18:41:39
Gents, Just bought a 444 RC and it will damn near break your arm steering it, especially in road high. Yes, I bought it sight un-seen. Waiting for manuals. I'm guessing bearing play up front. I've never torn into this end. Would appreciate input. My 44 RC steers like a dream.
Thanks,
Ben
marlowe
04-13-2006 17:43:15
 Re: 444RC Wheel wobble in reply to Ben Massey, 04-12-2006 18:41:39
also some times the bolts that holed the gear box down are busted so the hole box will move
marlowe
04-13-2006 17:41:33
most of the time the bearings in the steering gear box are junk from lack of oil and some times the gears are gone also you can try to take up the play with the ajuster on the gear box but most of the time thy are to far gone also the bearing at the bottem of the pedistal between the front wheels are shot from lack of grease. you did not say if you have PS if so your fix just got harder but it's the same parts that are shot
Charles H
04-14-2006 23:11:35
 Re: 444RC Wheel wobble in reply to marlowe, 04-13-2006 17:41:33
Hi there,
I also bought tractor unseen a 135 diesel, after having it for 3 month I finally got to drive it. It has wheel wobble extremely bad. It will toss you right off it, trying to stop the wobble while it is moving. Is it the same fix as the 444RC wheel wobble problem?
Thanks
marlowe
04-15-2006 04:27:02
 Re: 444RC Wheel wobble in reply to Charles H, 04-14-2006 23:11:35
no a differnt set up
Charles H
04-15-2006 10:18:44
 Re: 444RC Wheel wobble in reply to marlowe, 04-15-2006 04:27:02
Thanks for the reply. I'm waiting for the manuals to arrive, by chance is the problem an easy fix? Or am I going to have to take apart most of the upper end? Which unit is the problem?Again Thanks a million.
Charles
marlowe
04-15-2006 17:34:33
 Re: 444RC Wheel wobble in reply to Charles H, 04-15-2006 10:18:44
most of the time it's just the tie rod ends that are bad 4 of them 2 on each side
Charles H
04-15-2006 18:22:25
 Re: 444RC Wheel wobble in reply to marlowe, 04-15-2006 17:34:33
Thanks a million for the reply back.
I"ll see what I can do for it.
Again Thanks
