180 Tach Drive Alternator
B. Jones
04-19-2006 07:10:37
I noticed that YT Mag sells a tach drive Alternator for the MF 180. Our tractor has the old generator with the attachment on it. Does anyone know if the tach drive attachment from the generator will fit on the Alternator ? The ytmag Alternator does not come with the tach drive attachment. I would like to use the one from the generator if it will fit.
Tom Dold
04-19-2006 12:46:07
 Re: 180 Tach Drive Alternator in reply to B. Jones, 04-19-2006 07:10:37
B. Jones
According to the parts manual the tach drive is the same whether you have generator or an alternator. The gears are even the same. I beleive it will work as long as the replacement alternator is drilled for the tach drive mounting.
Tom Dold
Dold Implement
201 S. Main St.
PO Box 70
Howard, SD 57349 605-772-4541
dold@alliancecom.net
B. Jones
04-19-2006 10:25:40
I just talked with a guy who works on Alternators. He said the tach drive from a generator will not fit on an alternator.
