Oil Plug
Charles wilson
04-27-2006 04:58:14
On my 135 MF I have lost the washer/seal that goes on the oil plug and helps seal the plug to the oil pan after tightning, what little remains it looks like it was a thin steal washer, I need to get one, I made my on using two pieces of heavy gasket material. If anyone name or part # for this item I would appreciate it.
souNdguy
04-27-2006 12:12:42
 Re: Oil Plug in reply to Charles wilson, 04-27-2006 04:58:14
That paper gasket you made should work fine for the drain plug.. etc.
Soundguy
supergrumpy
04-27-2006 08:37:31
take your drain plug to NAPA, they should be able to match you up with good thick copper ring washer made to do what you want to do
Thanks
04-27-2006 09:33:43
 Re: Oil Plug in reply to supergrumpy, 04-27-2006 08:37:31
Appreciate the Advice
