Massey 30 industrial hydraulic problems
Bill Miller
04-27-2006 17:27:20
I have a MF 30 Industrial with a MF backhoe/loader with a 4 cyl Perkins Diesel. For some reason I have lost the power down on the boom for the backhoe. Everything else works great and the other functions on the backhoe and loader have good power with minimum drift. I removed the valve spool and it didn't appear worn,fouled or cracked and the spring was in good shape. When I engage power down the boom cylinder starts to move then stops. I thought I might have blown the cylinder seals yet there is very little boom drift and the cylinder doesn't blow by at the wiper around the ram. Anyone have any suggestions???
Big Dean
04-27-2006 19:40:28
 Re: Massey 30 industrial hydraulic problems in reply to Bill Miller, 04-27-2006 17:27:20
If I remember right the boom valve has a relief valve on each end of it they take either an 1-1/8 or maybe an 1-1/4 wrench to remove them switch place with them and see if you have down pressure if you do the boom will not raise and that relief valve is bad.
