Massey 65 Steering
Aaron Ford
05-01-2006 18:10:31
I am disassembling the front end and was wondering if anyone knew how to take the inner tie rod ends off. The one that attaches to the pitman arm (from steering gear) is a real puzzler. Thanks in Advance, Aaron
Dan S (NY)
05-02-2006 09:44:28
 Re: Massey 65 Steering in reply to Aaron Ford, 05-01-2006 18:10:31
On the Pitman arm tie rod end, you should be able to pull the rubber boot down and find an area where you can get a wrench on it. On my MF50, I just cut the boot off because I was replacing it anyway.
Dan
Aaron Ford
05-02-2006 16:11:43
 Re: Massey 65 Steering in reply to Dan S (NY), 05-02-2006 09:44:28
Thanks, I couln"t see anything evident but I haven"t looked under the boot yet. I have decided to pull everything for sandblasting. I need to see what is going on anyway. The spindles looked great from the outside, too....
