PROBLEM! MF 35 Perkins Blowing Oil from breather
benny2
05-07-2006 10:48:25
My MF 35 P3 diesel is blowing excessive oil from breather. It dont smoke out the exhaust starts and runs good with plenty of power or heat up. But is blowing a lot of oil out. Seems to have WAY to much crank case pressure. Am I right in thinking that this may be a head gasket leaking into the push rod sections. If it isn't that what else could it be. Besides rings.
Thanks
Jerry/MT
05-07-2006 21:39:10
 Re: PROBLEM! MF 35 Perkins Blowing Oil from breath in reply to benny2, 05-07-2006 10:48:25
You've either got a worn rings or a hole in a piston.
benny2
05-07-2006 23:11:24
 Will find out Re:PROBLEM! MF 35 Perkins Blowing Oi in reply to Jerry/MT, 05-07-2006 21:39:10
Will find out soon. I have ordered a head gasket set and will pull the head when the gasket set comes I guess. It could be rings but it runs to good to be a hole in a piston. As all cyl have decent compression and it runs smooth. Like this one kind of has me stumped because it nither uses water or gets hot and I been pulling it hard. Just blows oil out the breather pipe.
