Massey Ferg Bleeding of Hydraulic on Front 4x ram
B Bello
05-07-2006 14:27:13
Since I removed the Hydraulic ram to replace the connector to wheel, the steering is not working.
I have tried bleeding the system from the hydraulic lines to ram when the front end is off air/revving up the tractor/and manually moving wheels. The steering began to work while the front end up in the air. Is there any where else that air can be bled from the system? This is an older M. Ferg. 254. Thanks!
jrhopf
05-12-2006 17:12:58
 Re: Massey Ferg Bleeding of Hydraulic on Front 4x in reply to B Bello, 05-07-2006 14:27:13
I"m having a similiar problem with my 202 Work Bull since I replaced the hydralic lines I get power assist turnin right but none to the left? There must be air in the system. Anxious to see responses to your inquiry
