MH30
Aowner
05-09-2006 20:51:25
Just bought a MH30 that has been setting up for about 5 years. Got it running but the fuel is old and probably needs a good carb. cleaning. Runs good but under any load it will shut down or start skipping.
Rod in Smiths Falls, ON,
05-11-2006 19:48:35
 Re: MH30 in reply to Aowner, 05-09-2006 20:51:25
My 30 has a habit of quitting unexpectedly as if the gas line is plugged. It turned out to be the float sticking in the carb and a tap with a draw bolt just above the centre line of the carburetor provides an instant, if temporary cure. I have the kit and the float now, but haven't taken the thing apart because it still runs pretty well and this way nobody borrows it.
BigMarv 1085
05-09-2006 20:55:43
Do not let OLD work on your carb. Just kidding, remove old gas and rinse out gas tank, clean out carb., and file and reset your points.
