Hi C.T. Sorry it took so long, and it is not a good answer.SNFY 360173 is a 1964 model. But, I can't figure out the F... normally they had only 3 letters. My original UK shop manual does not say anything about the F letter. Anyway, a 3 cyl. diesel engine is what was offered in 1964, actually it may be the 35X, with the little stronger engine. Massey Ferguson bought Perkins in first half of 1959, and around mid year or so they stopped using the 23C engine and went over to the 3-152 Perkins engine. Those 35 that came with gas or TVO came with the Standard 87 mm engine. The plate may indicate FE 35, Massey Ferguson was not so particular about that on those tractors. Did you know that Harry Ferguson Ltd is still going strong, it is still a registrated company and as far as I know still sits on all the copyrights, patends, and such things for the grey Fergusons. The hood on your tractor has a different look than the TE/TO series, and the later MF 35 built in the US. The UK hood has some similarities with the hood Harry Ferguson intended to use on the big Ferguson that was never built. I hope this helps, and if you need more info, just ask. I am still working on mine to get it on the road. By the way, yesterday I saw a MF 35 with rear mounted winch and half tracks in forest use. I haven't seen half tracs on a MF in oh so long. In the same area I also saw a MF 135 with half tracks and rear mounted winch for forest use. Good to see someone still using them. All the best from Bill
