replacing parts while a tractors split
chris sweetland
05-13-2006 18:35:31
ok when i split my mf 65 to replace the transmission input seals what elis should i replace i know i need to do the clutch and what parts to that should i replace? and did i miss anything that should be done while im in there thanks chris
Dave_Id
05-14-2006 04:33:36
 Re: replacing parts while a tractors split in reply to chris sweetland, 05-13-2006 18:35:31
The rear main seal, or is that the same as the transmission input seal? The 65 I had was dumping a quart every half hour thru the rear main seal. It wasn't too bad to replace.
DavidP, South Wales
05-14-2006 00:14:32
Hi,
Have a close look at the release bearing and the starter ring. Suggest replacement of spiggot bearing and rear crank seal.
Check bolts tight in lower gearbox front cover.
DavidP
