Massey Ferguson 2200 loader backhoe fluids
John C MF 2200
05-22-2006 06:42:31
Just bought the above tractor - according to deans site it has the continental z134 engine.
The loader backhoe system uses type A tranny fluid according to the manuals, but I dont have manuals for the tractor itself.
What fluids are used in the "transmission"? and what oil grade is recomended for the engine?
Big Dean
05-22-2006 19:58:26
 Re: Massey Ferguson 2200 loader backhoe fluids in reply to John C MF 2200, 05-22-2006 06:42:31
When the oil companies start to do away with the old type A oil in the late 1970s we had a service bulletin from MF telling us to either 10 wt motor oil or the Trans/Hyd used in them it was M1129A at that time today it is Permatran 3. There idea for using the Trans/Hyd oil was so you did not have to keep but one oil on hand.
Alex Alexander
12-24-2006 07:22:17
 Massey Ferguson 35 Hydraulic Problem in reply to Big Dean, 05-22-2006 19:58:26
My Massey Ferguson 35 has a problem with the 3 pt Hitch. When you put the clutch in, it goes down, if the rpm is low, it will not move up or down and when the rpm drops, the lift goes down if there is a weight on it. If the enging is turned off, the lift drops immediately. Any ideas, Big Dean,I would really like to hear your views. I need to get this thing going, I have the Lift cover off and was surprised there is no filter on the pump that I can see!
