Help installing diverter on MF35
tennfire
05-29-2006 20:25:09
I picked up one of these off of Ebay with a small bag of o-rings but no instructions. Anyone have instructions on how to install it?
www.tractorshed.com/gallery/pieces/v2477.jpg
tennfire
05-31-2006 06:53:41
 Re: Help installing diverter on MF35 in reply to tennfire, 05-29-2006 20:25:09
David and Dean, Thanks for the information. That clarifies things quite a bit.
I do have a related inquiry. The cover plate that I am removing looks as if it has a 3/8" port on it that faces toward the seat at about a 45 degree angle. What is that port for? I assume it attaches at the top of the standpipe but for what?
DavidP, South Wales
05-31-2006 02:26:30
Hello,
You should have 3 'O' rings and 2 white PTFE coiled back-up washers. If you have not removed the cap on the tractor, remove the two 7/16 bolts. Twist the cap slightly and lift. The pipe that is fitted underneath may come out with the cap. If it does, great! If not use a pliers and gentle grip and twist and lift the pipe. Once disengaged from the pump underneath DO NOT drop it as it will be very difficult to retrieve. You will see the rings at each end of the pipe. The white washers are to be fitted away from the ends. You will also see one 'O' ring under the cap. Fit new washers and insert the pipe into your valve with the new seperate O ring fitted.
Fit the assembly into the tractor housing and downwards very carefully. The pipe has to engage with the pump. You will 'feel' when it has started. Get down and look across the gap. It should be equal all round. If so press the cap down gently and refit the bolts. Some valves require socket head bolts as there is not enough room for the hexagon or socket. Check.
If your tractor has Pressure Control you will not be able to remove the tube. Fit new rings and finish off as above.
Regards
DavidP South Wales
Yep
05-30-2006 06:13:01
third party image
Your photo
Yep
tennfire
05-30-2006 06:34:33
 Re: Help installing diverter on MF35 in reply to Yep, 05-30-2006 06:13:01
Not my photo or my tractor, it is a photo I found on this forum of one of those things already mounted. What i am looking for help on is the half-dozen or so o-rings that came with it.
Dean
05-31-2006 04:30:23
 Re: Help installing diverter on MF35 in reply to tennfire, 05-30-2006 06:34:33
Because you have no way of knowing whether the O-rings are the correct ones for the stand pipe or even if they have been used, I recommend that you get 2 new O-rings for the stand pipe and 2 new teflon back-up washers also. Install these on the stand pipe as David instructed.
You will need to use your own judgment as to the use of any of the rest of the O-rings that may or may not be needed for the valve that you have.
Dean
