change mf 50 to alternator
CLYDE EDDY
05-31-2006 16:45:45
I have a MF 50. I use it to mow. I want to convert it to an alternator. I have an alternator that has one lug with a nut and a elect. plug with one red wire and one white wire. the alternator has a built in voltage regulator. I know the Lug is wired to the battery. Where is the red and white connected.
jra
05-31-2006 21:05:58
 Re: change mf 50 to alternator in reply to CLYDE EDDY, 05-31-2006 16:45:45
The red wire goes to the lug with the nut on your Alt. The white one goes to your switch, or you could run it to the batt post on your coil.
CLYDE EDDY
06-01-2006 18:21:21
 Re: change mf 50 to alternator in reply to jra, 05-31-2006 21:05:58
thank you jra.....
