MF-202 PTO
Chuck 2
06-01-2006 10:12:22
Can't get pto to engage. Have the 102 loader and 220 backhoe, Don't know if pto works,recent purchase. Don't know lingo for tractors . What does draft mean also" pto ground" and "pto engine"What is procedure for engaging PTO on this machine Thanks, anyone who can help
smokey2
06-01-2006 20:10:51
 Re: MF-202 PTO in reply to Chuck 2, 06-01-2006 10:12:22
Does the PTO go in with the engine off? If it does then the 2 stage clutch requires adjustment.
This is a common problem and Big Dean Austin has good instructions on his site.
meadova
06-01-2006 18:34:16
Draft has to do with the lift. It is for plowing and such, you set the draft to the desired depth and as the terrain changes the lift changes to keep desired depth. Pto ground means the pto only turns when the tractor is moving the faster the tractor goes the faster the pto. Pto engine means the pto turn in speed according to engine speed. As for engaging pto depends whether is live power or independent. Most you press clutch all the way down move pto lever. Independent has a seperate lever to take pto in and out of gear.
