MF 135 Clutch
Agwrench
06-04-2006 19:49:00
I'm trying to locate the correct measurement for the release levers height on a MF135 SN9AI49000. The book calls for tooling MFN202C, but does not give dimensions, I need to fabricate one ASAP, It's Haying season, and my customers are running frantic. Please help
Big Dean
06-05-2006 07:25:01
 Re: MF 135 Clutch in reply to Agwrench, 06-04-2006 19:49:00
Through the years the replacement pressure plate assembles have been changed several times there are 4 or 5 of the tools to set the release finger height. They can be set with out the tool. You screw the adjusting bolts in till you have about 3 threads past the thick part of the fingers. Then measure from the pto disc to the head of all 3 bolts to be sure they are the same distance from the pto disc. I have set more like that than I have with the tool. If the bolts are run in to far they will hit the rivets of the pto disc causing it not to release.
