Distributor part needed for Massey with continenta
bjb in NE
06-08-2006 19:57:46
I am in need of the upper cam assembly for the delco distributor on a continental F-140 engine. I have a Massey 35 SP combine that I am trying to get running. The model of the distributor is 1111716. I believe this same engine was used on massey 22, 23 as well as oliver 44 tractors. Any ideas on where I could find this peice or a whole salvage distributor?
Al47
06-09-2006 18:36:00
 Re: Distributor part needed for Massey with contin in reply to bjb in NE, 06-08-2006 19:57:46
Try a dist. from a Case VAC I put one in a model 81.Had to change bottom gear
Al
massey333
06-09-2006 06:00:49
I wouldn't disagree with you,but Massey never used anything but Auto-lite or Presto-lite dist.or starter,generators on their tractors.Some of the dist.parts are not avalable and can not be rebuilt.If you do have a Delco you are in luck.
Jerry/MT
06-08-2006 21:28:19
These guys rebuilt the ditributor($100 + shpg) on my '54 TO-30 w/ Continental Z129 engine last year and they specialize in older stuff. www.philbingroup.com they are located in Portland, OR. (800-869-7301)
