Big Dean, oscillator pump tube question
castorriver
06-14-2006 18:42:30
Big Dean, the nut is about 1" inside diameter with a hole in the top. I have a picture posted to the left under the HELP IDENTIFY column under the title MF 245 1979. If it is the oscillator pump tube cap, how hard is it to get it back on there? Can I remove the hydraulic cover and screw it back on? What will happen if I can't get it back on? Thanks in advance. Doug.
Big Dean
06-15-2006 03:59:34
 Re: Big Dean, oscillator pump tube question in reply to castorriver, 06-14-2006 18:42:30
I don't think there is room to get down to where it screws back on I think you would have to remove the pump. It will not hurt anything to run it without it on there. I would just put it up till I had to remove the pump for something then you can put it back
castorriver
06-15-2006 19:33:47
 Thanks Big Dean in reply to Big Dean , 06-15-2006 03:59:34
Thanks for the info.
