Lower Link Pivot Shaft
BP in Texas
06-15-2006 20:29:48
The lower link pivot shaft threaded end is broken in the rear housing.
Any ideas?
Simon Ridout (UK)
06-16-2006 00:19:48
 Re: Lower Link Pivot Shaft in reply to BP in Texas, 06-15-2006 20:29:48
You do not state the model. If a 35/135 you need to drain the rear end and take off the trumpet (rear axle housing) to replace the pivot shaft.
Aaron Ford
06-16-2006 16:08:02
 Re: Lower Link Pivot Shaft in reply to Simon Ridout (UK), 06-16-2006 00:19:48
On a 65 you have to do the same, sans draining the belly. Unbolts from the inside. 65s are used parts only while other models (135)are still being produced.
