smokin hot brake
44Spl
06-18-2006 12:17:28
Replaced brakes (disc) on my 44 Special and seals. They work great but on its maiden voyage (first road trip) there was smoke and lots of heat coming up from the brake adj. on the right. Tractor doesn't pull when touching brakes also has hand clutch on that side which works properly . What have I done ??
Many thanks,
mn.Chuck
06-19-2006 05:05:08
 Re: smokin hot brake in reply to 44Spl, 06-18-2006 12:17:28
I agree. Until the disks are "broke in" you can't
set them up fully. After a little use you can set
up and you won't have trouble. Chuck
meadova
06-18-2006 17:38:36
Sounds like brakes adjusted to tight.
