MF 135 Issues
Christos
06-18-2006 21:33:34
Ok I got two questions for you all - 1) How does one get a sheared starter safety switch out of the tranmission case of a 67 135 Gas Deluxe? I can't get it out - and I tried putting a bolt in the hole where the black plastic piece is to try and use a socket to get it out. I bought a easy-out, but its too small for the hole and the next size up I think might be too big - 5 to a 6.
2) My tractor's H-N-L shift lever is frozen in the neutral position. My tractor hasn't moved since it stopped working 6 weeks ago and before that it sat 13 years and that lever still worked. I tried gently rapping on it - no dice - I also tried Blaster P.B.
I would appreciate whatever help you can give me.
Christos
smokey2
06-19-2006 14:54:38
 Re: MF 135 Issues in reply to Christos, 06-18-2006 21:33:34
Try Big Deans site for the stuck shifter - he has it covered on page 2. As for the switch all I would do is what any plumber wuold do. Jam a square piece of rod through the switch. Plumbers do this all the time with broken pipes.
