Pulley question for MH 81/82/20/22 ???
Alberta Mike
06-21-2006 10:18:18
I picked up a pulley drive assembly unit from a scrap yard for my MH 20. It has no pulley on it, just the outside flange on the end of the assembly shaft with the 4 bolt locations to attatch something to. What exactly was (is) available as a bolt on for these tractors? Are we talking a steel pulley, paper pulley, v-belt pulley, chain sprocket? Or maybe all or some of the above?
mn.Chuck
06-21-2006 18:38:07
 Re: Pulley question for MH 81/82/20/22 ??? in reply to Alberta Mike, 06-21-2006 10:18:18
In the parts book for the 20 and 22 it only shows
the 9 l/2" Rockwood pulley(Rpl by metal in later
years) Other machines and of other brands likely
had their own types of pulleys etc to drive from
this output shaft. Chuck
Ian Johnsen
06-21-2006 16:30:20
I saw an 81 at a salvage yard that had a v pulley on it that ran to a jack shaft to a sickle mower. The set up was totally home made. I have also seen the standard belt pulley. It must have been 6 or 8 inches wide. You can also get a cover. These do not bolt on like the bigger masseys. There have spring clips that slip over the back of the housing behind the flange.
