MF85 Cessna hydraulic pump
bryan hayes
06-22-2006 18:33:07
The pump off my MF85 lost pressure abruptly. Did a pressure test and found it down to 500PSI, check the screens and found material like babbit maybe, hopefully not cluth. Anyway took the pump out and found the shafts were so sloppy because the bushings (manual calls bearings) are very worn. Anybody know where to get a rebuild kit? My local dealers are saying they aren't available at all. Some of the gasket are there, but not the bushings. If I could get a whole kit I would feel better about it. Thanks guys
bryan hayes
06-26-2006 16:48:51
 Re: MF85 Cessna hydraulic pump in reply to bryan hayes, 06-22-2006 18:33:07
Thought I added this already, but the pump model is a 15602-4c. Any thoughts on where to find parts or a pump? My local shops say they are not available. Thanks!
J Schwiebert
06-23-2006 09:01:02
If your bushing are worn your center section is also worn. You will also need it. On the front flange of the pump will be a Cessna number. Find that number, you will need it and your best bet will be someone who handles Cessna. Cessna is part of Eaton hydraulics. When I taugh a pump class for the competition the popular thing was if your rebuild parts cost 60% of a new pump, buy the new pump. Also flush the sytem will and change filters often at first. Questions?
