MF 285 multipower
BigART
06-26-2006 16:35:57
When a multipower going out on a 285 mf, which range do you lose, the high side or low side? Thanks much, BigART
Big Dean
06-26-2006 19:04:31
 Re: MF 285 multipower in reply to BigART, 06-26-2006 16:35:57
You would loose the high side it takes pressure to engage the clutch pack for high range when the pressure is released it goes into low range without pressure it will stay in low range regardless of where the shift lever is set.
