MF 180
BigMarv1085
06-28-2006 04:44:59
Going to go look at a MF 180 this weekend. The brakes aren't working and the multipower only works in low.What is most likely wrong with multipower and is there some quick check you can do. Only want $1500.
marty g.
06-29-2006 04:50:42
 Re: MF 180 in reply to BigMarv1085, 06-28-2006 04:44:59
The multi-power could be something as simple as the lever being out of adjustment. If you have power-steering and 3 point hitch working, the MP should be functional. It is only a gear being moved by hydraulic pressure once engaged. For the brakes, if there is no adjustments left, it`s a bit more complicated, the axles trumpets have to be removed to service the brakes. The price is right anyway, I would jump on an occasion like that, but I'm mechanically incline, so I would do these repairs myself. For someone not so incline, it could be a difficult endeavor.
