TO35 brake adjustment
Brad Brown
07-04-2006 13:29:34
Can anyone give me a little advice on adjusting the brakes on my old TO35? I didn't see any adjustments on the linkage. Is it internally and if so where?
Thanks in advance.
Brad
phil(va)
07-04-2006 19:13:59
 Re: TO35 brake adjustment in reply to Brad Brown, 07-04-2006 13:29:34
Should be star wheels, accessible via holes on inside of drums. Jack up wheel. Shine light in there and you can see the star wheel gear. You can turn the star wheels by engaging blade of screwdriver between cogs of star wheel and flipping screw driver horizontally. If memory serves (manual not handy), move screw driver handle toward axle to tighten. Get tight, then back off enough for wheel to turn easily. Once you spot the star wheel thru the access hole these instructions will make more sense (I hope).
