Strange 3 cyl. crank.
Bill Brox
07-05-2006 09:09:05
Hi all. Has anyone heard about a 3 cyl. crank with a chain sprocket on instead of a regular gear ?
I have come across some used and a few new parts from a man who repaired a lot of Ferguson and MF tractors. It is a lot of TE 20 parts, and some MF 35 and some MF 135 parts. But, then this strange crank was in the boxes too.
Bill
Arthur from Tassy
07-07-2006 01:26:40
 Re: Strange 3 cyl. crank. in reply to Bill Brox, 07-05-2006 09:09:05
Hi Bill. Could the crank with the chain cog be for the earlier Perkins P3 motor ? I will try and find a work shop manual for the P3 and have a look, although the idea of Smokey2 that it is for driving something at the front of the motor is feasible.
Cheers Arthur from Tassy
smokey2
07-05-2006 14:58:50
Could be for an industrial Perkins application. These motors were made for a number uses. Which end is the sprocket? The industrial AD152 has a different harmonic balancer and timing case. It is designed so the full horsepower of the motor can be taken from the front of the motor.
Bill Brox
07-05-2006 15:48:45
 Re: Strange 3 cyl. crank. in reply to smokey2, 07-05-2006 14:58:50
It has a 3 row chain sprocket in front. But normally I thought Perkins used gears, and not a chain.
Bill
richard in nz
07-09-2006 03:03:10
 Re: Strange 3 cyl. crank. in reply to Bill Brox, 07-05-2006 15:48:45
The 'P' Series of Perkins engines (P3, P4, & P6 familys) all used triplex timing chain.
