MF245 lubing the steering box
Castorriver
07-09-2006 09:52:33
I have the repair manual for the MF245 but I can't figure out how/where to check or add lubricant to the steering box. It is a diesel with power steering and there is a cylinder on the left side of the engine. Thanks.
Aaron Ford
07-10-2006 07:58:58
 Re: MF245 lubing the steering box in reply to Castorriver, 07-09-2006 09:52:33
The MF65 had a steering box mounted on the transmission/clutch housing. This converted rotation of the steering wheel to linear force to operate the steering gear which was mounted in front of the radiator. This, in turn, operated the steering linkage between the front tires. The steering box was greased with 80-90 gear oil. It has a fill plug mounted on the side, but I have yet to find a drain.
MF#1
07-09-2006 12:30:51
Yes, Jon is correct, front right, below alternator, square head pipe plug, use MF hydraulic fluid or equivalent. I would not use auto trany fluid, BTDT.
jonjon
07-09-2006 11:56:25
The fluid goes in the powersteering pump. front right of the engine i think. manual should show it.
