Will a 444 Massy Harris 3 Point fit a RC 44
Charles TX
08-05-2006 19:27:46
Will a Massey Harris 444 3 point bolt up to a 1951 RC 44. The PTO is lower on the 444 and it appears the center link would be problem.
Harris Guy
08-05-2006 20:15:56
 Re: Will a 444 Massy Harris 3 Point fit a RC 44 in reply to Charles TX, 08-05-2006 19:27:46
The Hitch-All on a 444 requires extensive fabrication to adapt to a 44. The earlier version
on '54 & '55 44 Specials, will basically bolt up
to a 44 with central hydraulics, Depth-o-Matic.
However, these can sell for 4-7 hundred. For a 44
you need that liftshaft design that bolts above the PTO housing; the rest are junque. Good Luck.
MHfox
08-07-2006 05:50:11
 Re: Will a 444 Massy Harris 3 Point fit a RC 44 in reply to Harris Guy, 08-05-2006 20:15:56
You say "the rest are junk". What is the problem with the under PTO 3 point? Is there a fix to the problem? What is the capacity difference between the two 44 lifts?
Harris Guy
08-07-2006 11:09:10
 Re: Will a 444 Massy Harris 3 Point fit a RC 44 in reply to MHfox, 08-07-2006 05:50:11
They were early efforts to build a 3 point, similar to the cultivator lift. A 30 could get by
with no rough use, with this. More cat. I than
durable. The lift arm anchor pins lacked clevis
supports, the lift arms cracked, vertical linkage
and pins broke. 44's just ruined the assembly part
by part. The Hitch-All was cat. II, well braced, durable. Some late 33's had Hitch-All, as did 44
Specials, however it remained an option on each
tractor.
