MF 65 epicyclic red. gear specifications.
Bill Brox
08-16-2006 11:20:16
Hi all,
Does anyone know the play or pre-load on the rear wheel flange on a MF 65 Mk I from 1960. I am replacing the wheel bearings, and need to shim it up when assembling. But, unfortunately I don't know the play or pre-load on the bearings.
I hope someone can help.
Thanks in advance, Bill
Aaron Ford
08-16-2006 12:33:57
 Re: MF 65 epicyclic red. gear specifications. in reply to Bill Brox, 08-16-2006 11:20:16
Set your shims to provide .001-.005" preload. You can do this by omitting a .010 shim and adjusting for .005 clearance, then reinstall the .010 shim. Good Luck
Bill Brox
08-16-2006 13:49:24
 Re: MF 65 epicyclic red. gear specifications. in reply to Aaron Ford, 08-16-2006 12:33:57
Thanks, Aaron
I wonder if shims of brass is good enough, I do not have too many shims of steel, and the original ones are not longer available.
Bill
Aaron Ford
08-18-2006 17:37:02
 Re: MF 65 epicyclic red. gear specifications. in reply to Bill Brox, 08-16-2006 13:49:24
Ouch, I got the info out of my manual. I did not know that they were not available. Not sure about brass, but I cannot see it hurting to try. Mine were tight so I have not messed with 'em. Perhaps a salvage yard? 65's seem to be plentiful there. Likely due to the cost of rebuilding the Continental. Cheers Aaron
