lead substitute?
john d g
08-20-2006 14:36:33
have a MF 50 with a contin z-134 gas engine---do these old tractors require lead added to todays gasoline---thanks john
Actor
08-21-2006 21:47:29
 Re: lead substitute? in reply to john d g, 08-20-2006 14:36:33
Hope it is OK to ask this question here, I am new to this site. I have an old MH tractor. The plate states that it is a 102 SS. # 362071. These numbers don't match anything I find on the web. Under the trans it is stamped 06 19 45. I am guessing that is the date of build.
Any ideas?
Thanks in advance
New Message
08-22-2006 06:04:09
 Re: lead substitute? in reply to Actor, 08-21-2006 21:47:29
It's best to start your own 'subject' by clicking on the "Post Message" near the top under the red MH MF banner. That way all the answers you get will be only about your question.
old
08-20-2006 21:02:24
The lead stuff is a waste of money and it doesn't even have any lead in it any way. Its just a snake oil that someone makes to get people to spend money for no good reason.
Gerald J.
08-20-2006 14:56:34
Only if you like changing lead fouled plugs and are plowing 50 acres a day with it. Otherwise you might wear the valve seats out in 50 years of unleaded.
Gerald J.
benny2
08-20-2006 18:48:05
 That just isnt so! Here is how to Re:lead substitu in reply to Gerald J., 08-20-2006 14:56:34
It is not the valve seats that wear out from the lack of lead. Lead in fuel did 2 things it lubed the guides and raised the octain rating of gass. The valve seats burn from the newer fuels and it is recomemed that the guides and seats be replaced with more suitable matieal designed for NO Lead fuels. But like Gerald J said unless you are into the real use of these machines you shouldnt worry.
But there is a way to add lead to the old tractors fuel with little cost and benifits to the tractor. Get a hand full of OO Buck shot or larger and put it in the Gas tank. There will be enough to roll off the shot and chemicaly desolve in the fuel to replace the lost lead. Make sure the shot is much larger than the fuel outlet though so it wont wedge in there and plug the lines. This shot will also keep the bottom free of dirt from dust from settling on the bottom this is the largest cause of rusted bottoms with the addtion of condensation. Add a little wood Alky in the winter to get rid of water.
